[About] Address
Press [About] or open [About] [Tab 29], then select an address. The following contextual tabs of information about the selected address will be displayed.
{Address}
{Address} displays the following information:
- Address number (displayed as straight address and port/ offset)
- Dimmer label (if any)
- Associated channel number, which is a hyperlink to the [About] channel display.
- Part number (if any)
- Notes
- Output value (sACN, Art-Net, or DMX)
- Current output value and source of output
- Parameter controlled by the address
- Home Value
- Basic patch information
- Extended patch information (if available)
- If it is a scroller, color/ gobo wheel, the assigned scroll or wheel is indicated
- Information stored in the Text 1 through10 and the Notes fields in Patch > Database
{Next Part} and {Last Part} will advance to the next part or go back to the previous part. This only displays for addresses with parts.
{Go To Patch} is a shortcut to edit the patch for the address selected. This will open up the patch display.
{Fixture Notes}
{Fixture Notes} displays the following information:
- Revision number
- Release date
- Open issues list (if available)
- Usage notes including switch settings and configuration (if available)
- Alternate fixture names (if any)
{Lamp Controls}
{Lamp Controls} displays controls for the lamp or other parameters of the device (if it is an automated fixture).
{Next / Last Unpatched}
{Next/ Last Unpatched} will allow you to see what addresses closest to the current address are currently unpatched.
{Dimmer Feedback}
{Dimmer Feedback} - appears when the current address is patched to a dimmer in an ETC Sensor rack with a CEM+ or CEM3. Sensor feedback must be enabled and the CEM+ must be running software version 3.0 or later. See Interface Protocols.
{Dimmer Feedback} displays the following information:
- Name (dimmer name)
- Module type
- Rack/Position
- Rack dimmer level (displayed as a percentage)
- Rack dimmer source
- Recorded load
- Actual load
{Dimmer Feedback} also allows you to modify the following information about the selected address:
- Firing Mode
- Control Mode
- Curve
- Threshold
- Scale Minimum
- Scale Maximum
- Preheat Enable
- Preheat Timing
- Advanced Features (AF) Enable
Select any value to modify it and enter a new one.
The following softkey commands are supported from this display:
- {Ignore Errors}
- {Clear Errors}
Clearing CEM+ or CEM3 errors will be temporary unless the errors have been fixed at the CEM+ or CEM3. Errors displayed will clear on their own once they have been cleared from the CEM+ or CEM3. Some CEM+ or CEM3 errors can only be cleared at the Sensor rack.
{Device Details}
This option appears when the current address is patched to a Network RDM device. RDM devices must be enabled through the Eos Configuration Utility (ECU) and discovered through Patch [Tab 12].
{Device Details} displays the information that it receives from the device; etails displayed will vary based on the device. Changes can be made to:
- Device Label (displayed at the top by the address number)
- DMX Address (can be changed in this display by clicking on the property or value)
- DMX Label (same as the device label, but the label can be changed here by clicking on the property or value)
- Type
- Manufacturer
- Device ID
- Footprint
- Versiond
- Lamp State
- Lamp Hours
- Head DC Voltage
- Lamp On/Off
- Gel Distance Traveled
- Gel2 Distance Traveled
- Fan RPM
- Ambient Temperature
- Gel Temperature
Changes may take a few seconds to make, as they need to propagate to the RDM device and then back to Eos.
{Device Errors}
A red exclamation mark (!) or a yellow question mark (?) is used in Patch, Live (see Indicators in Live and Blind), Patch, [About] Channel, and [About] Address to indicate Eos has detected Errors and Warnings from connected RDM, CEM+, CEM3, or ACN devices.
Errors and warnings are indicated based on severity using the following colors:
- Gray - unknown or not an error.
- White - an advisory: something that might be worth knowing about but likely won't affect system operation.
- Yellow - a warning: something you should know about that may affect system operation. Warning messages could include:
- Multiple device addresses overlap.
- A mismatch between the patched fixture type and the real fixture.
- A mismatch between the patched address and the fixture address.
- A device is offline.
- Red - an error: something definitively wrong that is likely or certain to affect system operation. Error messages could include:
- A circuit is over temperature (overtemp).
- A breaker has tripped.
- A lamp is out.
The relative severity of an error in any given device is determined by the device manufacturer.
Use {Clear Errors} to remove displayed errors from the list.
